Hi All,
I was wondering if anyone would be able to help me out with a problem that I'm having. For some reason, when I go to mirror a Component in my Assembly across the Right Plane, the mirrored part turns out as a rotated version of the original part instead of a mirrored part. If you take a look at the attached photos, you can see the original look, the Plane that the Components are mirrored about and the final product. If you look at the last picture, you can see that the holes aren't as they should be. Each half circle should line up and make a proper hole shape through the combined two pieces.
Thank you in advance
Alexander,
When you have your mirror feature properties window open, first select your parts and plane. Then in the upper right click the arrow for the next page, where you have the option to make an Opposite-hand version, which gives the option to create a new part from the mirror or a new configuration in your existing part. I'm not too savy on the SW version specs, but I think this was available after 2010.
