SW: you guys'd better learn how to listen to the users pls.
I'd requested this option from the very beginning when I started using SW back 2007 ver.
Why the default colors are green and yellow? it's hard to recgonize the diff. - what's wrong of using some diff. colors like yellow and brown or blue
I use the draft analysis many times each day and I have to change the colors each time I used this option and the bad thing is, the defaul colors is back and the change from the user is never saved as most of other softwares - the only thing being saved is the draft angle
I'm so tired of the adds that you guys are listening to the customers
While I do not have problems with the Green/Yellow (my eyes have no problem seeing the difference), I have been raising as much of a ruckus as I can about being unable to "set default colors" easily. While I have no doubt any decent code monkey could jump into the system regestry and find/fix/set the colors...there is no place in the SW GUI to do it. And the color default that totally rubs me raw is the freaking default color for negative draft...Red. As soon as you select "Gradual transition", the system will show both "Zero Draft" and "Enough Draft in the Negative Direction" as RED!!! Worse yet, the "color legend" makes you think that it should be blue. So stuff with zero draft AND stuff with negative draft show as RED!!! COMPLETELY USELESS AND REQUIRES THE USER TO MANUALLY CHANGE THE COLOR EVERY SINGLE TIME!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
I keep on submitting this, talking to VARs about it, bringing it up every time I can.....NOTHING.
