Hey Gang,
New to EPDM admin, but making headway and actually understanding most of it ! The situation is this... I have a transition that sends files from an Approved state to a WIP state. In that transition, the 'Revision' is changed from (example) A to A+ via Value %Revision%+. This results in my contents of Revision being "A+".
I'm creating an "UNDO" transition, and don't know how to remove the "+" and keep the "A". I know I can redefine/replace it, but short of having another variable (i.e. TempRevision), is there any way to remove specified text from a variable text string?
Thanks!
In this case we do a rollback which eliminates it from the history as if it never happened. This is a must for us because if someone adds a drawing to a particular ECO, the ECO number gets applied to the data card. If the drawing was placed on ECO by mistake or needs to be removed then another transition to set it back to previous revision still leaves ECO number in place. Even if the user puts the previous ECO number back in the field, the other ECO it was mistakenly put on is still part of the history and thus this drawing will show up on an ECO number search.
