2 Replies Latest reply on Dec 13, 2012 1:05 AM by Chris Day
    Adding configuration-specific custom properties
    Chris Day
      Hi there,
      I'm adding configurations to some parts, during which I'm trying to insert a configuration-specific "Description" custom property depending on the value of Description in the code below. However, the correct values are not being written to the new configuration, and instead it's as if the first configuration's property is being added to all of the configurations. I've inserted the bolded lines to try and connect to the active configuration after it's created. I'm not really sure if the problem lies here.
      I'd appreciate any help.
      On a side note, when I comment out the first lines and uncomment the next two I get a host of weird errors. Does anyone know the reason for this?
      Many thanks,
      Chris
      Dim swApp As Object
      Dim swModel As Object
      'Dim swApp               As SldWorks.SldWorks
      'Dim swModel             As SldWorks.ModelDoc2
      Dim swConfigMgr         As SldWorks.ConfigurationManager
      Dim swConfig            As SldWorks.Configuration
      Dim swCustPropMgr       As SldWorks.CustomPropertyManager
      Dim retVal              As Long
      Dim boolstatus As Boolean
          Set swModel = swApp.ActiveDoc
          Dim myModelView As Object
          Dim Description() As String
          Set swConfigMgr = swModel.ConfigurationManager
          Set swConfig = swConfigMgr.ActiveConfiguration
          Set swCustPropMgr = swConfig.CustomPropertyManager
          ' Get File Name without grade as first part of Description text
          Dim PartName As String
          PartName = Left(swModel.GetTitle, InStrRev(swModel.GetTitle, ",")) & " "
          ' Apply new configurations
          ReDim Description(3)
          Description(0) = "Grade A4"
          Description(1) = "Grade 8.8"
          Description(2) = "Grade 10.9"
          Description(3) = "Grade 12.9"
          Dim i As Integer
          For i = 0 To UBound(Description)
              boolstatus = swModel.AddConfiguration2(Description(i), "", "-", False, False, False, True, 1048833)
                  Debug.Print PartName & Description(i) ' <--- should be configuration "Description" text
              swCustPropMgr.Add2 "Description", swCustomInfoText, PartName & Description(i)
         Next i
          swModel.DeleteConfiguration2 "Default"
        • Re: Adding configuration-specific custom properties
          Artem Taturevych
          Try this modified macro:
              Dim i As Integer
                  swModel.AddConfiguration3 Description(i), "", "-", 0
                  Set swCustPropMgr = swModel.Extension.CustomPropertyManager(Description(i))
                  swCustPropMgr.Set "Description", PartName & Description(i)
             Next i
          ______________________
          Regards,
          Artem Taturevych
          Application Engineer at Intercad
          http://intercad.com.au/
          Tel: +61 2 9454 4444
