4 Replies Latest reply on Dec 13, 2012 8:48 AM by Cloud Strife Pom Cloud Strife Pom
    Get selection point in sketch segment
      I want to get the XYZ coordinate point in sketch segment (a 3DSketch Line)
      but when i'm using GetSelectionPoint() it will always return the start point in the sketch segment (no matter part of the line, except end point)
      how can I solve this problem?
      and another question is
      I want to use CreateBodyFromCyl() while I draw a 3DSketch Line.
      it will display cylinder body with direction and distance snap with the line (after draw start point (first time)) and delete the cylinder after finish drawing a line (work as a preview).
      can anyone give me an idea?
      thanks you.
        • Re: Get selection point in sketch segment
          Artem Taturevych
          I have used the following example:
              Set swModel = swApp.ActiveDoc
              Dim vSelPt As Variant
              vSelPt = swSelMgr.GetSelectionPoint2(1, -1)
          3D Sketch is opened
          Sketch line is selected as first object
          I have correct result and the vSelPt array contains the coordinates of selection (pick point) but not end points.
          Second question.
          You have chosen the correct method. This method will create a temporary body for you. Use Body2::Display3 to display/preview this body and just set the pointer to null to remove the preview because the temporary bodies are living until the pointer is not destroyed.
          Artem Taturevych
          Application Engineer at Intercad
          Tel: +61 2 9454 4444
