5 Replies Latest reply on Sep 7, 2018 11:40 AM by Deepak Gupta
    how do I get a solidworks sketch dimensional value
    Michael Skinner
      in order to use it in another sketch dimension function?
      Retreiving the value and setting the function using VB code?
        • Re: how do I get a solidworks sketch dimensional value
          Keith Rice
          Hi Michael,
          Welcome to the forums. The following code will change the value of D2@Sketch1 to the value of D1@Sketch1. You can change the names of the dimensions to whatever you need for it to work in your context.
          Dim swDim As SldWorks.Dimension
          Dim vDimVal As Variant
              Set swModel = swApp.ActiveDoc
              Set swDim = swModel.Parameter("D1@Sketch1")
              vDimVal = swDim.GetSystemValue3(swThisConfiguration, Empty)
              Set swDim = swModel.Parameter("D2@Sketch1")
              swDim.SetSystemValue3 vDimVal(0), swThisConfiguration, Empty
          Alternatively, if you need to programmatically determine the name of the dimension, you can use IDimension::GetNameForSelection or IDisplayDimension::GetNameForSelection. Note the difference between IDisplayDimension and IDimension. The former is what is visble to the user---it is the dimension annotation. The latter, however, is what actually has the dimension value.
          There's many more code examples that you might find useful at my web site, and we also cover this material in Lesson 4.1.
          Keith
          Video Tutorials for the SolidWorks API
              Michael Skinner
              thanks Keith,
              maybe I didn't make myself clear enough in the beginning. So if the following makes the values of D1@Sketch1 & D2@Sketch1 the same then..
              then this will make the value of D2@Sketch1 equal to 1/4 the value of D1@Sketch1?
              Set swDim = swModel.Parameter("D1@Sketch1" * 0.25)
              thank you in advance
              Michael
                  Keith Rice
                  Hi Michael,
                  No, IModelDoc2::Parameter does not get or set the dimension value, it gets the IDimension pointer. So if your goal is to make D2 1/4th the size of D1 then you need this:
                      swDim.SetSystemValue3 vDimVal(0) * 0.25, swThisConfiguration, Empty
                  Keith
                Alvaro Clemente
                Hi! I have kinda of the same issue, but I also need to get the name of each dimension from each feature to retrieve its name and value to a list for documentation pourposes. Is that possible?
