0 Replies Latest reply on Dec 8, 2012 11:10 PM by Robert Cruz
    Any recomendations of study for a CSWE Exam ?
    Robert Cruz
      I just found an unique exam to determine a level of proficiency in Solidworks @ http://www.solidprofessor.com/lang/en/affiliates/tests/default.asp?c=10&e=24&accid=78 is that kind of test we will have at SW CSWE ? the SOLIDWOKS Site does not give any hints on that matter, i guess a CSWE has to do a test without have any knowledge of which format will be ....Any recomendations besides the Forum https://forum.solidworks.com/thread/30962 ?
      Also i found the referenced topics a sufficient tip is that the completed list below ?
      Surface Modifications
      Opening a part document
      Working with Surfaces
      Deleting the faces
      Measuring the angle
      Rotating the handle
      Recreating the surfaces
      Hiding a solid body
      Trimming the surfaces
      Showing a surface body
      Knitting all surface bodies
      Creating a section view
      Measuring the mass
      Assembly Modifications
      Opening an assembly document
      Editing the first component
      Adding Draft
      Viewing the draft results
      Editing the second component
      Replacing a plane
      Repairing the sketch errors
      Correcting the end condition
      Exiting the edit component mode
      Measuring the center of mass
      Using manual drafts
      The Order of Fillets
      Comparing the fillet results
      Planning the order of fillets
      Adding the face fillet
      Creating the constant fillet
      Adding another constant fillet
      Measuring the mass
      Fillet Options
      Flat Spring Assembly
      Starting a new part template
      Creating the helix - the sweep path
      Creating the sweep profile
      Adding the pierce relation
      Creating the swept feature
      Creating an axis
      Inserting the part into an assembly
      Showing the axis
      Adding mates
      Checking the degrees of freedom
      Adding coincident mates
      Applying dimension changes
      Viewing the results
      Calculating the center of mass
      Spring Assembly
      Part Modifications
      Modifying the model
      Converting the outline of a feature
      Deleting the on-edge relations
      Removing the raised feature
      Creating a cut
      Recreating the sweep path
      Using projected curve
      Creating a swept feature
      Calculating the mass
      Part modifications
      Replacing External References
      Examining the existing mates
      Suppressing the inplace mate
      Adding a concentric mate
      Editing a component
      Replacing the sketch plane
      Viewing the external ref. symbols
      Adding new mates
      Adding a distance mate
      Working with Multibody Parts
      Switching to the part level
      Editing a feature
      Using Move / Copy / Constraint
      Adding mates
      Changing the display option
      Using the combine command
      Using combine add
      Switching back to assembly
      Rebuilding the assembly
      Exercise: Combining Multibodies
      Creating a Curved Spring
      Creating the sweep path
      Setting the twist type
      Entering the number of turns
      Assigning the material
      Calculating the final mass
      Exercise: Circular Spring - Expanded
      Working with Sketch Pictures
      Creating a layout sketch
      Inserting the picture
      Locating the picture
      Scaling the picture
      Tracing the picture
      Creating the offset entities
      Closing the traced sketch
      Adding the sketch fillets
      Adding the revolved centerline
      Revolving the sketch profile
      Measuring the mass of the part
      Sketch picture - Eagle head
      Using Cut With Surface
      Editing a component
      Creating a surface offset
      Creating a surface cut
      Flipping the cut direction
      Hiding a component
      Hiding a surface
      Adding fillets
      Cut with Surface
      Using Belt Chain
      Creating the main sketch
      Making the blocks
      Creating a belt chain
      Entering the belt length
      Adding the driving angular dimension
      Adding a reference dimension
      Checking the new belt length
      Changing the pulley's angle
      Entering the new belt length
      Exercise: Creating a belt chain
      SolidWorks Commands Icons and Toolbars.
