8 Replies Latest reply on Dec 8, 2012 7:27 PM by Glenn Schroeder
    Construction Lines/Points in Drawings
    Kevin Biancamano
      I just created a new template for my company with the correct size, and now when i try and create a point at a theoretical sharp corner or construction line it is over-defined or screws up somehow. It is like the construction lines or points are acting as if they are part of an actual drawing and  not just annotation. I know the sharp features option can sometime work but when it is not a true chamfer it will not work. This was not a problem with my old template so I was not sure if there was just an option I could change or something.
      If you click on the dwg view it will say over defined.
      Thank you,
      Kevin
