I have a bunch of screw models with multiple configurations per part file. When I look at the BOM or the contains tab for the assemblies using these screw models, sometimes the right referenced configuration is found, but sometimes it isn't (and thus reverts to the @ configuration). How does PDM search for the referenced configuration? Is there something wrong with how the assemblies were built in SolidWorks that is causing this issue?
Sally
I had some times the same issue. One workaround that I use is to open assemblies with @ in SW and make from there the checkin. This way the BOM is correct.
