3 Replies Latest reply on Jan 14, 2013 11:00 AM by Bjorn Hulman
    Setting the default file filter to 'All files' in the File > Open dialog is a limitation in SolidWorks. This is because the default file filters are coded internally and they cannot be changed externally.
    Sean Trainor
      A customer asked me about changing the default file filter to all files. On searching through knowledge base I came across solution S-032662 from 2008 which states the above answer.
      I would like to know whether or not this is now an option in 2012 or 2013 as I cannot seem to find an answer relating to these releases.
      Regards,
      Seán
