JLJohn Lhuillier05/12/2012
We have a customer that requires dimensions to the edge of a hole for a quick check. So figured I'd ordinate dimension from the straight edge of the part to the center of the hole & then change it to be the min dimension. Should work in theory but finding that doing this gives me the wrong dimension. I dimensioned the same holes the same way using baseline dimensioning & get a different distance to the edge of the hole. On the attached the 1.343 & 1.346 are supposedly dimensioned to the same edges & the 2.401 & 2.404 as well bet they are off & shouldn't be. Have sent it to our VAR but haven't heard back from them & also to warn people about this.This happens in both 2012 SP4 & 2013 SP1EV
