2 Replies Latest reply: Dec 5, 2012 5:26 AM by Yong Ning
    How to change text in Model with API.
    Yong Ning
      macro recorded code follow bottom.
        Set Part = swApp.ActiveDoc
        Set SelMgr = Part.SelectionManager
        boolstatus = Part.Extension.SelectByID2("Sketch2", "SKETCH", 0, 0, 0, False, 0, Nothing, 0)
        Part.EditSketch
        boolstatus = Part.Extension.SelectByID2("SketchText1", "SKETCHTEXT", 0.09499532772996, 0.01014076720589, 0, False, 0, Nothing, 0)
      Aim: Hope change note in SkethcText1.
      Thanks.
          • Re: How to change text in Model with API.
            Yong Ning
            Thanks tips
            'Get All Elements of Sketch Example (VB)
            'This example shows how to get all of the elements of a sketch.
            ' Preconditions: Model document is open and a sketch is selected.
            ' Postconditions: None
            Option Explicit
            Public Enum swSkSegments_e
                swSketchLINE = 0
                swSketchARC = 1
                swSketchELLIPSE = 2
                swSketchSPLINE = 3
                swSketchTEXT = 4
                swSketchPARABOLA = 5
            End Enum
            Sub ProcessTextFormat _
            ( _
                swApp As SldWorks.SldWorks, _
                swModel As SldWorks.ModelDoc2, _
                swTextFormat As SldWorks.TextFormat _
                Debug.Print "        BackWards                    = " & swTextFormat.BackWards
                Debug.Print "        Bold                         = " & swTextFormat.Bold
                Debug.Print "        CharHeight                   = " & swTextFormat.CharHeight
                Debug.Print "        CharHeightInPts              = " & swTextFormat.CharHeightInPts
                Debug.Print "        CharSpacingFactor            = " & swTextFormat.CharSpacingFactor
                Debug.Print "        Escapement                   = " & swTextFormat.Escapement
                Debug.Print "        IsHeightSpecifiedInPts       = " & swTextFormat.IsHeightSpecifiedInPts
                Debug.Print "        Italic                       = " & swTextFormat.Italic
                Debug.Print "        LineLength                   = " & swTextFormat.LineLength
                Debug.Print "        LineSpacing                  = " & swTextFormat.LineSpacing
                Debug.Print "        ObliqueAngle                 = " & swTextFormat.ObliqueAngle
                Debug.Print "        Strikeout                    = " & swTextFormat.Strikeout
                Debug.Print "        TypeFaceName                 = " & swTextFormat.TypeFaceName
                Debug.Print "        Underline                    = " & swTextFormat.Underline
                Debug.Print "        UpsideDown                   = " & swTextFormat.UpsideDown
                Debug.Print "        Vertical                     = " & swTextFormat.Vertical
                Debug.Print "        WidthFactor                  = " & swTextFormat.WidthFactor
                Debug.Print ""
            Function TransformSketchPointToModelSpace _
            ( _
                swSketch As SldWorks.Sketch, _
                swSkPt As SldWorks.SketchPoint _
            ) As SldWorks.MathPoint
                Dim swMathUtil              As SldWorks.MathUtility
                Dim swXform                 As SldWorks.MathTransform
                Dim nPt(2)                  As Double
                Dim vPt                     As Variant
                Dim swMathPt                As SldWorks.MathPoint
                nPt(0) = swSkPt.X:      nPt(1) = swSkPt.Y:      nPt(2) = swSkPt.Z
                vPt = nPt
                Set swMathUtil = swApp.GetMathUtility
                Set swXform = swSketch.ModelToSketchTransform
                Set swXform = swXform.Inverse
                Set swMathPt = swMathUtil.CreatePoint((vPt))
                Set swMathPt = swMathPt.MultiplyTransform(swXform)
                Set TransformSketchPointToModelSpace = swMathPt
            End Function
            Sub ProcessSketchLine _
            ( _
                swSkLine As SldWorks.SketchLine _
                Dim swStartPt               As SldWorks.SketchPoint
                Dim swEndPt                 As SldWorks.SketchPoint
                Dim swStartModPt            As SldWorks.MathPoint
                Dim swEndModPt              As SldWorks.MathPoint
                Set swStartPt = swSkLine.GetStartPoint2
                Set swEndPt = swSkLine.GetEndPoint2
                Set swStartModPt = TransformSketchPointToModelSpace(swApp, swModel, swSketch, swStartPt)
                Set swEndModPt = TransformSketchPointToModelSpace(swApp, swModel, swSketch, swEndPt)
                Debug.Print "      Start (sketch)   = (" & swStartPt.X * 1000# & ", " & swStartPt.Y * 1000# & ", " & swStartPt.Z * 1000# & ") mm"
                Debug.Print "      Start (model )   = (" & swStartModPt.ArrayData(0) * 1000# & ", " & swStartModPt.ArrayData(1) * 1000# & ", " & swStartModPt.ArrayData(2) * 1000# & ") mm"
                Debug.Print "      End   (sketch)   = (" & swEndPt.X * 1000# & ", " & swEndPt.Y * 1000# & ", " & swEndPt.Z * 1000# & ") mm"
                Debug.Print "      End   (model )   = (" & swEndModPt.ArrayData(0) * 1000# & ", " & swEndModPt.ArrayData(1) * 1000# & ", " & swEndModPt.ArrayData(2) * 1000# & ") mm"
            Sub ProcessSketchArc _
            ( _
                swSkArc As SldWorks.SketchArc _
                Dim swCtrPt                 As SldWorks.SketchPoint
                Dim vNormal                 As Variant
                Dim swCtrModPt              As SldWorks.MathPoint
                Set swStartPt = swSkArc.GetStartPoint2
                Set swEndPt = swSkArc.GetEndPoint2
                Set swCtrPt = swSkArc.GetCenterPoint2
                Set swCtrModPt = TransformSketchPointToModelSpace(swApp, swModel, swSketch, swCtrPt)
                vNormal = swSkArc.GetNormalVector
                Debug.Print "      Center(sketch)   = (" & swCtrPt.X * 1000# & ", " & swCtrPt.Y * 1000# & ", " & swCtrPt.Z * 1000# & ") mm"
                Debug.Print "      Center(model )   = (" & swCtrModPt.ArrayData(0) * 1000# & ", " & swCtrModPt.ArrayData(1) * 1000# & ", " & swCtrModPt.ArrayData(2) * 1000# & ") mm"
                Debug.Print "      Radius           = " & swSkArc.GetRadius * 1000# & " mm"
                Debug.Print "      IsCircle         = " & CBool(swSkArc.IsCircle)
                Debug.Print "      Rot dirn         = " & swSkArc.GetRotationDir
            Sub ProcessSketchEllipse _
            ( _
                swSkEllipse As SldWorks.SketchEllipse _
                Dim swMajPt                 As SldWorks.SketchPoint
                Dim swMinPt                 As SldWorks.SketchPoint
                Dim swMajModPt              As SldWorks.MathPoint
                Dim swMinModPt              As SldWorks.MathPoint
                Set swStartPt = swSkEllipse.GetStartPoint2
                Set swEndPt = swSkEllipse.GetEndPoint2
                Set swCtrPt = swSkEllipse.GetCenterPoint2
                Set swMajPt = swSkEllipse.GetMajorPoint2
                Set swMinPt = swSkEllipse.GetMinorPoint2
                Set swMajModPt = TransformSketchPointToModelSpace(swApp, swModel, swSketch, swMajPt)
                Set swMinModPt = TransformSketchPointToModelSpace(swApp, swModel, swSketch, swMinPt)
                Debug.Print "      Major (sketch)   = (" & swMajPt.X * 1000# & ", " & swMajPt.Y * 1000# & ", " & swMajPt.Z * 1000# & ") mm"
                Debug.Print "      Major (model )   = (" & swMajModPt.ArrayData(0) * 1000# & ", " & swMajModPt.ArrayData(1) * 1000# & ", " & swMajModPt.ArrayData(2) * 1000# & ") mm"
                Debug.Print "      Minor (sketch)   = (" & swMinPt.X * 1000# & ", " & swMinPt.Y * 1000# & ", " & swMinPt.Z * 1000# & ") mm"
                Debug.Print "      Minor (model )   = (" & swMinModPt.ArrayData(0) * 1000# & ", " & swMinModPt.ArrayData(1) * 1000# & ", " & swMinModPt.ArrayData(2) * 1000# & ") mm"
            Sub ProcessSketchSpline _
            ( _
                swSkSpline As SldWorks.SketchSpline _
                Dim vSplinePtArr            As Variant
                Dim vSplinePt               As Variant
                Dim swSplinePt              As SldWorks.SketchPoint
                Dim swSplineModPt           As SldWorks.MathPoint
                vSplinePtArr = swSkSpline.GetPoints2
                For Each vSplinePt In vSplinePtArr
                    Set swSplinePt = vSplinePt
                    Set swSplineModPt = TransformSketchPointToModelSpace(swApp, swModel, swSketch, swSplinePt)
                    Debug.Print "      Spline (sketch)  = (" & swSplinePt.X * 1000# & ", " & swSplinePt.Y * 1000# & ", " & swSplinePt.Z * 1000# & ") mm"
                    Debug.Print "      Spline (model )  = (" & swSplineModPt.ArrayData(0) * 1000# & ", " & swSplineModPt.ArrayData(1) * 1000# & ", " & swSplineModPt.ArrayData(2) * 1000# & ") mm"
                Next vSplinePt
            Sub ProcessSketchText _
            ( _
                swSkText As SldWorks.SketchText _
                Dim vCoordPt                As Variant
                Dim swCoordModPt            As SldWorks.MathPoint
                vCoordPt = swSkText.GetCoordinates
                Set swCoordModPt = swMathUtil.CreatePoint((vCoordPt))
                Set swCoordModPt = swCoordModPt.MultiplyTransform(swXform)
                Debug.Print "      Coords (sketch)  = (" & vCoordPt(0) * 1000# & ", " & vCoordPt(1) * 1000# & ", " & vCoordPt(2) * 1000# & ") mm"
                Debug.Print "      Coords (model )  = (" & swCoordModPt.ArrayData(0) * 1000# & ", " & swCoordModPt.ArrayData(1) * 1000# & ", " & swCoordModPt.ArrayData(2) * 1000# & ") mm"
                Debug.Print "      Use doc fmt      = " & swSkText.GetUseDocTextFormat
                Debug.Print "      Text             = " & swSkText.Text
                ProcessTextFormat swApp, swModel, swSkText.GetTextFormat
            Sub ProcessSketchParabola _
            ( _
                swSkParabola As SldWorks.SketchParabola _
                Dim swApexPt                As SldWorks.SketchPoint
                Dim swFocalPt               As SldWorks.SketchPoint
                Dim swApexModPt             As SldWorks.MathPoint
                Dim swFocalModPt            As SldWorks.MathPoint
                Set swApexPt = swSkParabola.GetApexPoint2
                Set swStartPt = swSkParabola.GetStartPoint2
                Set swEndPt = swSkParabola.GetEndPoint2
                Set swFocalPt = swSkParabola.GetFocalPoint2
                Set swApexModPt = TransformSketchPointToModelSpace(swApp, swModel, swSketch, swApexPt)
                Set swFocalModPt = TransformSketchPointToModelSpace(swApp, swModel, swSketch, swFocalPt)
                Debug.Print "      Apex  (sketch)   = (" & swApexPt.X * 1000# & ", " & swApexPt.Y * 1000# & ", " & swApexPt.Z * 1000# & ") mm"
                Debug.Print "      Apex  (model )   = (" & swApexModPt.ArrayData(0) * 1000# & ", " & swApexModPt.ArrayData(1) * 1000# & ", " & swApexModPt.ArrayData(2) * 1000# & ") mm"
                Debug.Print "      Focal (sketch)   = (" & swFocalPt.X * 1000# & ", " & swFocalPt.Y * 1000# & ", " & swFocalPt.Z * 1000# & ") mm"
                Debug.Print "      Focal (model )   = (" & swFocalModPt.ArrayData(0) * 1000# & ", " & swFocalModPt.ArrayData(1) * 1000# & ", " & swFocalModPt.ArrayData(2) * 1000# & ") mm"
                Dim sSkSegmentsName(5)      As String
                Dim swApp                   As SldWorks.SldWorks
                Dim swModel                 As SldWorks.ModelDoc2
                Dim swSelMgr                As SldWorks.SelectionMgr
                Dim swFeat                  As SldWorks.Feature
                Dim swSketch                As SldWorks.Sketch
                Dim vSkSegArr               As Variant
                Dim vSkSeg                  As Variant
                Dim swSkSeg                 As SldWorks.SketchSegment
                Dim swSkLine                As SldWorks.SketchLine
                Dim swSkArc                 As SldWorks.SketchArc
                Dim swSkEllipse             As SldWorks.SketchEllipse
                Dim swSkSpline              As SldWorks.SketchSpline
                Dim swSkText                As SldWorks.SketchText
                Dim swSkParabola            As SldWorks.SketchParabola
                Dim vID                     As Variant
                Dim i                       As Long
                Dim bRet                    As Boolean
                sSkSegmentsName(swSketchLINE) = "swSketchLINE"
                sSkSegmentsName(swSketchARC) = "swSketchARC"
                sSkSegmentsName(swSketchELLIPSE) = "swSketchELLIPSE"
                sSkSegmentsName(swSketchSPLINE) = "swSketchSPLINE"
                sSkSegmentsName(swSketchTEXT) = "swSketchTEXT"
                sSkSegmentsName(swSketchPARABOLA) = "swSketchPARABOLA"
                Set swModel = swApp.ActiveDoc
                Set swFeat = swSelMgr.GetSelectedObject5(1)
                Set swSketch = swFeat.GetSpecificFeature
                Debug.Print "Feature = " & swFeat.Name & " [" & swSketch.Is3D & "]"
                Debug.Print "  Sketch Segments:"
                vSkSegArr = swSketch.GetSketchSegments
                For Each vSkSeg In vSkSegArr
                    Set swSkSeg = vSkSeg
                    vID = swSkSeg.GetID
                    Debug.Print "    ID = [" & vID(0) & "," & vID(1) & "]"
                    Debug.Print "      Type             = " & sSkSegmentsName(swSkSeg.GetType)
                    Debug.Print "      ConstGeom        = " & swSkSeg.ConstructionGeometry
                    Select Case swSkSeg.GetType
                        Case swSketchLINE
                            Set swSkLine = swSkSeg
                            ProcessSketchLine swApp, swModel, swSketch, swSkLine
                        Case swSketchARC
                            Set swSkArc = swSkSeg
                            ProcessSketchArc swApp, swModel, swSketch, swSkArc
                        Case swSketchELLIPSE
                            Set swSkEllipse = swSkSeg
                            ProcessSketchEllipse swApp, swModel, swSketch, swSkEllipse
                        Case swSketchSPLINE
                            Set swSkSpline = swSkSeg
                            ProcessSketchSpline swApp, swModel, swSketch, swSkSpline
                        Case swSketchTEXT
                            Set swSkText = swSkSeg
                            ProcessSketchText swApp, swModel, swSketch, swSkText
                        Case swSketchPARABOLA
                            Set swSkParabola = swSkSeg
                            ProcessSketchParabola swApp, swModel, swSketch, swSkParabola
                        Case Default
                            Debug.Assert False
                    End Select
                Next vSkSeg
            Code  Result
            Feature = Sketch2 [False]
              Sketch Segments:
                ID = [0,1]
                  Type             = swSketchLINE
                  ConstGeom        = True
                  Start (sketch)   = (0, 10, 0) mm
                  Start (model )   = (0, 10, 0) mm
                  End   (sketch)   = (100, 10, 0) mm
                  End   (model )   = (100, 10, 0) mm
                ID = [0,1]
                  Type             = swSketchTEXT
                  ConstGeom        = False
                  Coords (sketch)  = (4.65384615384616, 10, 0) mm
                  Coords (model )  = (4.65384615384616, 10, 0) mm
                  Use doc fmt      = False
                  Text             = Solidworks
                    BackWards                    = False
                    Bold                         = False
                    CharHeight                   = .015
                    CharHeightInPts              = 42
                    CharSpacingFactor            = .9
                    Escapement                   = 0
                    IsHeightSpecifiedInPts       = False
                    Italic                       = False
                    LineLength                   = 0
                    LineSpacing                  = .001
                    ObliqueAngle                 = 0
                    Strikeout                    = False
                    TypeFaceName                 = Century Gothic
                    Underline                    = False
                    UpsideDown                   = False
                    Vertical                     = False
                    WidthFactor                  = 1
            Sub lls1()
              Dim tmp, sss As SldWorks.Sketch, Arr
              Dim swSketchText As SketchText
            ' Get the selected feature of the sketch text
              tmp = swModel.Extension.SelectByID2("SketchText1", "SKETCHTEXT", 0, 0, 0, False, 0, Nothing, 0)
              tmp = swModel.Extension.SelectByID2("Sketch2", "SKETCH", 0, 0, 0, False, 0, Nothing, 0)
              Set swFeat = swSelMgr.GetSelectedObject6(1, 0)
              Set swSketch = swFeat.GetSpecificFeature2
              Arr = swSketch.GetSketchTextSegments
              Set swSketchText = Arr(0)
              Debug.Print swSketchText.Text
              Dim SwSketchTextFormat As SldWorks.TextFormat
              With swSketchText
                Set SwSketchTextFormat = .GetTextFormat
                Debug.Print .Text
              End With
              With SwSketchTextFormat
                Debug.Print .Bold, .CharHeight, .LineLength, .CharSpacingFactor
              End With
              tmp = swModel.Extension.SelectByID2("Wrap1", "BODYFEATURE", 0, 0, 0, False, 0, Nothing, 0)
              swModel.EditUnsuppress
              Path = swModel.GetPathName
              Path = Left(Path, InStrRev(Path, "\"))
              swModel.SaveAs2 Path & "me.EPRT", 0, True, False
              swModel.SaveAs2 Path & "me.PDF", 0, True, False
              swModel.EditSuppress
