We name our files by the Part Number but we also populate the
Number field with the part number and then hide the file name from
the PDMWorks view as was suggested elsewhere just so we don't see
the file extensions. To avoid having to fill in the part number in
PDMWorks you can create a property in each template called "Number"
and give it the following text $PRP:"SW-File Name" and the number
field will auto populate without the file extension.
Beware as PDMWorks overwrites this with the actual part number on check-in so it won't auto update if you rename a file.
Mark.
Mark.
It represents a good slice of the many applications for these properties as well as their intrepretation and intended use.
