Good afternoon,
Every time i try to open photoview it freezes on not responding and never finished loading. Can this be associated with a network license being unavailable due to a bad connection? It doesn't give any license errors, just freezes. I did not modify the contents of the program folder, add or remove any software files. This is solidworks 2011
Hi, I hope that you have resolved this problem by now. It sounds like the same problem I had and finally found a solution to.
For the benefit of others swearing at their computer . . .
Photoview 360 window flicking up briefly before terminating and SW freezing for some time before recovering.
Photoview 360 not responding
Photoview 360 not working
Check to see that the "Bonjour" Service is running. If it is not installed you can download from apple website. Modifying the SW install will re-install this service but a repair will not.
Hope that saves someone some time.
