9 Replies Latest reply on Jun 16, 2017 12:50 PM by John Malmberg
    Use EditFreeze in Assembly?
    Georg Draxler
      i am trying to use the API Method EditFreeze, but i don't want to open every part document, so i run
      through the whole model and put every part in edit mode.
      After that i use EditFreeze:
      Boolstat = featMgr.EditFreeze(swMoveFreezeBarTo_e.swMoveFreezeBarToEnd, "", False)
      But this is not moving the freezebar to the end of the featuretree. Boolstat says "False"
      The FeatMgr is from the modeldoc of the part in edit mode.
      Anybody know why this isn't working?
      Thanks for your help
        • Re: Use EditFreeze in Assembly?
          Artem Taturevych
          Try to use Feature Manager from Active model doc (i.e. assembly). When working in-context you should always use active document only (especially for feature creation). Even if it seems to work correct this may produce unexpected behaviour in future. Seen this a number of times.
          ______________________
          Regards,
          Artem Taturevych
          Application Engineer at Intercad
          http://intercad.com.au/
          Tel: +61 2 9454 4444
              Georg Draxler
              i tried now as you said, but using the assembly ModelDoc also doesn't work.
              Here is my sample code:
              For Each Component As sldworks.Component2 In Components
                          swDocForLoop = Component.GetModelDoc2
                          If swDocForLoop.GetType = swconst.swDocumentTypes_e.swDocPART Then
                              Component.Select4(False, seldata, False)
                              rootAssembly.EditPart2(True, False, editPartInfo)
                              Debug.WriteLine(editPartInfo)
                              Debug.WriteLine(Component.Name2)
                              fm.Freeze_(rootDoc) 'fm is an instance of a class. rootDoc is my Assembly where i call the programm
              Next
              Implementation of Freeze_
              Function Freeze_(ByVal swDoc As ModelDoc2)
                      Dim swModelDocExt As ModelDocExtension = swDoc.Extension
                      Dim featMgr As FeatureManager
                      Dim selMgr As SelectionMgr
                      Dim Boolstat As Boolean = True
                      Dim feat As Feature
                      'Dim swPart As SolidWorks.Interop.sldworks.PartDoc
                      'Get ModelDocs Featuermanager and Selectionmanger
                      featMgr = swDoc.FeatureManager
                      selMgr = swDoc.SelectionManager
                      feat = featMgr.GetFreezeLocation
                      'Move featurefreeze to bottom of featuretree if Model is not freezed
                      If feat Is Nothing Then
                      Else
                          Exit Function
                      'Check if model is freezed now
                      'If model is not freezed do a force rebuild and freeze again
                          swDoc.ForceRebuild3(False)
                  End Function
              I also tried to record a macro freezing a part in an assembly. it records the freeze methode but when i play the macro it doesn't freeze.
                  Michael Kozikowski
                  You need to have the assembly component document EXPLICITLY open for this to work, unlike the UI, it is required. The API requires a model view, so just open the component document and re-run the macro.
                      Georg Draxler
                      The assembly document is allready open. It is the document where i start the macro but i don't want to open every part document because it slows down the whole process. It would be nicer and faster to do this in edit mode.
                      I also tried now to open the part documents silent in backgound, but it didn't bring me to another result. Could you give me a code snippet? My precondition is only an open assembly.
                          Michael Kozikowski
                          With the component document explicitly opened, and the assembly document active, you should be able to edit the component freeze bar in the assembly context. This is required, but we have an SPR 652782 "Cannot IFeatureManager::EditFreeze move the freeze bar of a component in-context to an assembly without having the component document open" to address it. Please use the workaround described.
                              Georg Draxler
                              Sorry, but it dosen't work. Here is my current code:
                                      Dim swapp As sldworks.SldWorks = CType(GetObject(, "SldWorks.Application"), sldworks.SldWorks)
                                      Dim rootDoc As sldworks.ModelDoc2 = swapp.ActiveDoc
                                      Dim rootAssembly As sldworks.AssemblyDoc = rootDoc
                                      Dim selmgr As sldworks.SelectionMgr
                                      Dim seldata As sldworks.SelectData
                                      Dim swDocuments As Array
                                      Dim errors As Integer
                                      Dim warnings As Integer
                                      selmgr = rootDoc.SelectionManager
                                      seldata = selmgr.CreateSelectData
                                      Dim selObject As Object
                                      With selmgr
                                          selObject = .GetSelectedObject6(0, 0)
                                      End With
                                      swDocuments = rootDoc.GetDependencies2(False, False, False)
                                      Dim editPartInfo As swconst.swEditPartCommandStatus_e
                                      Dim Components As Array
                                      Components = rootAssembly.GetComponents(True)
                                      Dim swDocForLoop As sldworks.ModelDoc2
                                      Dim fm As New FeatureFreeze
                                      Dim docToOpen As sldworks.ModelDoc2
                                              docToOpen = swapp.OpenDoc6(swDocForLoop.GetPathName, _
        swconst.swDocumentTypes_e.swDocPART, _
        swconst.swOpenDocOptions_e.swOpenDocOptions_Silent, _
        "", errors, warnings)
                                              If docToOpen Is Nothing Then
                                                  docToOpen = swapp.GetOpenDocument(swDocForLoop.GetPathName)
                                              fm.Freeze_(docToOpen, rootDoc, swapp)
                                      Next
                              And here is the code of Freeze_:
                              Function Freeze_(ByVal swDoc As ModelDoc2, ByVal rootDocument As ModelDoc2, ByVal swApp As SldWorks)
                                      Dim feat As Feature
                                      Dim activeRootDoc As ModelDoc2
                                      Dim acterror As swActivateDocError_e
                                      'swApp.SetUserPreferenceIntegerValue(swUserPreferenceIntegerValue_e.swRebuildOnActivation, swRebuildOnActivation_e.swDontRebuildActiveDoc)
                                          activeRootDoc = swApp.ActivateDoc3(rootDocument.GetPathName, False, swRebuildOnActivation_e.swDontRebuildActiveDoc, acterror)
                                      Else
                                          Return False
                                          Exit Function
                                      Return True
                                  End Function
                              Please copy&past and give it a try. Please tell me where my error is.
                              If i activate the part component (activeRootDoc = swApp.ActivateDoc3(swDoc.GetPathName, False, swRebuildOnActivation_e.swDontRebuildActiveDoc, acterror) ) it works, but i don't want to activate the part. (with activate i mean that the part doc becomes the model currently showing in solidworks)
                              Added more Information
                              Artem Taturevych
                              Georg,
                              When you have an opened assembly with components not lightweight or suppressed that means that the models already loaded in memory and you can just make them visible instead of opening (this actually would be the same). In other words performance will be not critically decreased. Try the ModelDoc2::Visible property.
                              Regards,
                              Artem Taturevych
                        John Malmberg
                        I had the same problem.  I found the fix for me was turning on the Enable Freeze Bar checkbox in the System Options.
                        with it off, I could not change the freeze bar status.   With it was turned on, I was able to change it.
