Hi!
My problem is basically about the curve driven pattern, which should follow 3D scetch based on the headrest profile (pic. "ProblemII"). I've also added some pictures
to show what is the nature of my problem. As you can see on the picture "Problem" I'm trying make seams on the cover material of headrest, but it seems that tanget to
curve method under the property manager doesn't aply the change needed when using the 3D sketch. But when I make regular sketch out of one part of 3D sketch (part
thaht could be on sertain plane) it makes the seams tanget to curve, but this way is less productive and I have to make many separate features.
So I was wondering maybe someone has had the same problem or has a solution for making these seams work properly, please let me know, I would be very thankful.
