I need to create material for the composit which i want to add to the Solidworks material Library. This material i want to use in some simulation testing. I just stuck in very tight situation and i need it very uregently, So if any one can help me then please speak up..
Ashok
Hi Ashok: you can open the material library and create a new library of your own label directly in the material tree (right click and choose 'create new library'). Then you can copy one of the existing materials and paste it into your new library. You are now able to edit and modify the properties of the material you just pasted. hope that helps.
