Hi Guys
I have a problem and need help sorting it. I need to create a roof . I have attached a part with a base sketch and a sheet body.
I need to pattern the body within the required area. The sheets will fall short or over but the important thing is that the area dimensions will change according to clients sizes.
Also the sheet size will change as well.
I have setup a part but not sure if a assembly will be better,
