Does anybody know why I get this error ?(see picture) If I select coincident on the pop up menu when I select the entities, I get the error. However, I can go to the property manager and select it there no problem. Any ideas?
I am not sure if I am allowed to...
However, it happens in probably half of my parts I make so I don't think it is part related. Just a "local" glitch I guess?
If it happens on a lot of your parts, can you make a meaningless sample part just to reproduce the error (and upload here)?
If it happened on that great of a percentage of parts for me, I'd be talking to my VAR.
Seems odd to me. I could repeat the error, but then it would work both ways after I used the Prop Mngr then undid it.
Strange thing is if I used CTRL to select both, I got the error. Using SHIFT, no error...
It also worked for me if I clicked both items using CTRL, deselected one, then selected it again.
I could not, however, get it to repeat when I made a new part/sketch from my computer with the same setup.
Doesn't make any sense to me why SW would act like that. Can you post your part file?
