Hi All,
Can anyone tell me, if it’s possible, how to prevent the custom properties tab from reading a part. Every time I click a part its properties are read off the server and there is a 3-5 second delay before I can do anything else. This occurs with almost EVERY click on a different part. I thought it was my PC but we just upgraded to some kick-ars# PC’s and the problem persists.
the simplest should be to select a diferent tab (you may note that the property tab is "highlighted" or selected in the image you posted).
