I've been using pro on an iPad2 16G with some small machine assembling, works well. Assemblers don't have to find the engineer and ask a bunch of questions, that saves a lot of time and money. I do get an "out of memory" warning occasionally, and occasionally the program just quits. I'm not able to open files over 20MB, that presents a problem with larger and more complex machines. I now have authorization to buy four new iPads and load them up with eDrawings Pro, but I don't want this to blow up on me. Does eDrawings run better on iPad3? Is there a limit to how large an assembly will work with this?
This is an excellent app, I think a lot of shops are going to want this on their machining and assembly floors, but I don't want to get ahead of the developers with my investment dollars.
Scott Miller
Project Manager
Tric Tool
Holland, MI
Hi Scott,
The 4th generation iPad (current 10" model with retina screen) has 1 GB of RAM, while the iPad2 and iPad mini have half that. So you can expect the iPad4 to open larger assemblies than the iPad2.
Another thing you may want to consider: there are several new Windows 8-based devices in the tablet form factor on the market now (e.g. Acer Iconia W700, Dell XPS 12, Lenovo Thinkpad Tablet, etc.) that come with 4 GB or more of RAM. These are capable of running the "full" Windows eDrawings. So if it's model complexity you are most concerned about, I suggest taking a look at these also.
Hope this helps,
Vajrang.
