I want to modify the components that are in the default drop down list to what I want to use rather than what Solidworks uses as defaults. In other words I want to add a nut to the top stack as part of the default drop down list for when I use a Stud instead of a bolt where I have a nut on the top stack and a nut on the bottom stack. Can this be done?
I am trying to achieve the same, and was not able to find an answer around the net. Can anyone help?
I have made new fastener and have no problem using it, but how to change it so i can use nut on both top and bottom stacK?
thanks
