EFEric Finan26/11/2012
Hi All,
I'm trying to write a macro to solve an issue that surely others have: print out all of the drawings related to an assembly in order.  I have spent quite some time looking around for a macro that can do this, but haven't had any success, so I decided to write one.  I am new to VBA, but I'm familiar with some other programming languages.
I have two macros right now that each do half of what I ultimately want in the final macro:
  1. The first macro opens up all of the unique drawings related to the assembly (all parts/drawings are in the same directory), but doesn't print them in order shown in the tree.
  2. The second macro is able to identify the top level components in the tree in order and print the names to the immediate window, but prints all instances of each component.
What I'm thinking is that I can use the logic from the second macro (opening components in order) and apply that to the first macro, which is opening and printing unique drawings related to the assembly.  Can anybody else provide some insight to solving this?  It would be greatly appreciated and I will certainly post the final working macro here, as I have had enormous help from others' posts.
Macro One:
Sub ShowAllOpenFiles()
Dim swDoc As SldWorks.ModelDoc2
Dim swAllDocs As EnumDocuments2
Dim FirstDoc As SldWorks.ModelDoc2
Dim dummy As Boolean
Dim NumDocsReturned As Long
Dim DocCount As Long
Dim i As Long
Dim sMsg As String
Dim bDocWasVisible As Boolean
Dim OpenWarnings As Long
Dim OpenErrors As Long
Dim DwgPath As String
Dim myDwgDoc As SldWorks.ModelDoc2
Dim swPageSetup As SldWorks.PageSetup
Dim swDocName As String
Dim swDwgName As String
Dim CurrentDoc As SldWorks.ModelDoc2
Dim CurrentDocQuit As SldWorks.ModelDoc2
Set swAllDocs = swApp.EnumDocuments2
Set FirstDoc = swApp.ActiveDoc
DocCount = 0
swAllDocs.Reset
swAllDocs.Next 1, swDoc, NumDocsReturned
While NumDocsReturned <> 0
    bDocWasVisible = swDoc.Visible
    swApp.ActivateDoc swDoc.GetPathName
    DwgPath = swDoc.GetPathName
    If (LCase(Right(DwgPath, 3)) <> "drw") And (DwgPath <> "") Then
        DwgPath = Left(DwgPath, Len(DwgPath) - 3) & "drw"
        Debug.Print "Drawing =  " & DwgPath
        Set myDwgDoc = swApp.OpenDoc6(DwgPath, swDocDRAWING, swOpenDocOptions_Silent, "", OpenErrors, OpenWarnings)
        If Not myDwgDoc Is Nothing Then 'If a drawing exists for this part, then:
            swApp.ActivateDoc myDwgDoc.GetPathName
            Set myDwgDoc = Nothing
            '--PRINT SECTION--
            Set CurrentDoc = swApp.ActiveDoc
            Set swPageSetup = CurrentDoc.PageSetup
            swPageSetup.ScaleToFit = True 'Scale sheet to size
            swPageSetup.PrinterPaperSize = 1 'Print on Ledger (3) size or Letter (1) size
            CurrentDoc.PrintDirect 'Print to default printer
        '--CLOSE DOCUMENT--
        Set CurrentDocQuit = swApp.ActiveDoc
        swDwgName = CurrentDocQuit.GetTitle
        swApp.QuitDoc swDwgName 'Close drawing sheet
        swDocName = swDoc.GetTitle
        swApp.QuitDoc swDocName 'Close model
    DocCount = DocCount + 1
Wend
Macro 2:
'Written Feb 1, 09
'This Traverse the Manager tree and prints the components
'Out put is print to Immediate window of Folder names, Component names.
Dim Part As SldWorks.ModelDoc2
Dim SelMgr As SldWorks.SelectionMgr
Dim RootNode As SldWorks.TreeControlItem
Set Part = swApp.ActiveDoc
Set SelMgr = Part.SelectionManager
Set FeatureMgr = Part.FeatureManager
Set RootNode = FeatureMgr.GetFeatureTreeRootItem()
Traverse_Nodes RootNode, 1
Sub Traverse_Nodes(node As SldWorks.TreeControlItem, Level As Integer)
Dim Childnode As SldWorks.TreeControlItem
Dim Cnode As SldWorks.TreeControlItem
Dim Feat As SldWorks.Feature
Dim FeatTypeName As String
Dim comp As SldWorks.Component2
Dim CompDoc As SldWorks.ModelDoc2
Dim Indent As String
Indent = Space(Level * 4)
Set Childnode = node.GetFirstChild
If Childnode Is Nothing Then
    'An empty folder causes an empty node
    Debug.Print "      Empty Folder"
While Not Childnode Is Nothing
    'If the node is a feature type is 1
    If Childnode.ObjectType = 1 Then
        Set Feat = Childnode.Object
        FeatTypeName = Feat.GetTypeName
        'If the feature is a folder with part in it or a pattern with parts in it
        If FeatTypeName = "FtrFolder" Or InStr(FeatTypeName, "Pattern") > 0 Then
        'Prints the name of the folder and goes through the components
        Debug.Print Childnode.Text
            Traverse_Nodes Childnode, Level + 1
    'If the node is a component
    ElseIf Childnode.ObjectType = 2 Then
        Set comp = Childnode.Object
        Debug.Print Indent & comp.Name2
        Set Cnode = Childnode.GetFirstChild
     Set CompDoc = comp.GetModelDoc
        'This get parts and mates in subassemblies
        If Not CompDoc Is Nothing Then
            If CompDoc.GetType = 2 Then
                'This loops through subassemblies
                'To get Sub Comps unremark next line.
                'Traverse_Nodes Childnode, Level + 1  'XXXXXXXXXXXXXXXXXXXXXXXXX
    Else
        Debug.Print Indent & "Not Sure of node type"
NoSubs:
    Set Childnode = Childnode.GetNext
Wend
