Hi everyone,
I've always had a bit of an issue with Solidworks Weldments being used to design aluminum extrusion profiles.
I'm re-setting up my Solidworks custom weldment profiles after a re-install, and I figured now was a good time to get to the bottom of this.
I've downloaded the profile of the aluminum extrusion shown in the picture from the manufacturer (Bosch Rexroth).
I create a very simple 3D sketch, and added the weldments. As you can see in the image, clearly these are identical, yet the cutlist will not group them together.
Any ideas why?
Thanks.
Ok I've actually narrowed it down to the profile downloaded from Bosch - it's not perfect.
Some dimentions are off, although by extremely small amounts (like 10.000000912mm and 45.000023mm).
This is probably why SW isn't able to group them together.
The profile (as shown in the attached image) is pretty complex. What do you think would be the best way to fix this issue?
I tried dividing the profile in 4 quadrants, delete 3 of them, and mirroring the one mirror twice to make sure the profile is symetrical in all directions, but that's didn't work either...
