2 Replies Latest reply on Nov 26, 2012 1:39 PM by Adam Doerr
    Sub-Assembly Incrementing Macro Help
    Adam Doerr
      I'm hoping to create a macro that will let me manually select a sub-assembly in the tree and then run the macro through a hotkey to increment the sub-assembly to its next configuration. I've previously only created very simple macros or edited complex ones to slightly modify their function. Now I'm trying to use the online API help to try creating such a macro from scratch, but it seems quite difficult to find what I should even be searching for. I recorded a macro to start off with that basically does what I want, but it is too exact in it's funtion calls to allow me to run it again and again (ie; it keeps calling for the same configuration name). So far, it seems like CompConfigProperties4 is what I'll probably use according to my initial macro recording. I'm looking for some help/pointers on what functions I might want to use and any other tips you can give me. Any suggestions on other downloadable macros that might have pieces of code I an use would also be much appreciated.
        • Re: Sub-Assembly Incrementing Macro Help
          Keith Rice
          Hi Adam,
          Cool idea for a macro. You need to use ISelectionMgr to get the selected object, IComponent2::ReferencedConfiguration to get and set the component's configuration, IComponent2::GetModelDoc2 to get the underlying model of the component so that you can determine the names of the configurations, and IModelDoc2::GetConfigurationNames to get the names of the configs.
          This macro should accomplish what you need:
          Dim swCompModel As SldWorks.ModelDoc2
          Dim strCurrentConfigName As String
          Dim strNewConfigName As String
          Dim vConfigNames As Variant
          Dim i As Integer
              Set swModel = swApp.ActiveDoc
              Set swComp = swSelMgr.GetSelectedObject6(1, -1)
              strCurrentConfigName = swComp.ReferencedConfiguration
              Set swCompModel = swComp.GetModelDoc2
              vConfigNames = swCompModel.GetConfigurationNames
              For i = 0 To UBound(vConfigNames)
                  If strCurrentConfigName = vConfigNames(i) Then
                      If i + 1 > UBound(vConfigNames) Then
                          strNewConfigName = vConfigNames(0)
                          strNewConfigName = vConfigNames(i + 1)
                      swComp.ReferencedConfiguration = strNewConfigName
                      Exit For
              Next i
          I would highly recommend not using the online API Help. It is a lot harder to navigate. Instead, uncheck Help-->Use SolidWorks web help" before going to Help-->API Help. This will open the local API Help. I cover this and a lot more in Lesson 2.2 at my web site.
          Video Tutorials for the SolidWorks API
