Hi, can anyone help me with this kind of problem?
Attached is a drawing of a connector terminal. The part is a stamped and formed part, manufactured on a progression die. It has a number of transition areas and varying cross-sections.
I want to be able to create this kind of part, but the trick is to generate accurate models for both the fully formed part and the blank part, so that the part can be folded and unfolded accurately using the same 3D model.
Is this really possible with the SolidWorks sheetmetal functionality, or is there some add-on SW partner package that is needed? If the latter is the case, can you recommend the partner product that would be needed?
Thanks for your help!
Matt
You would probably need 3rd party software to flatten that part.
