I have a 6000mm long beam that now requires a 30mm camber to be introduced at the center. The radius would be 150015mm
Rather than re - creating the part to show this camber I think I can use the Flex command to create this extra camber on the straight girder.
However when I try, I can only get it to create a sweep in the beam i.e. it goes left or right rather than up.
How do I change the axis line so it goes correct way.
If someone could post video showing the steps to archive this I would be very grateful, any size section will do as an example
See below what i would like to do is the bottom drawing.
Mark (SolidWorks 2012 sp5)
Edit the triad and change the angle for Y axis. Check the settings from my file.
