I don't know what I have done.
Was creating variables in EPDM and linking to an Excel file.
I didn't change the serial number but for some reason it is skipping numbers, assigning every other number.
I don't see where the increment value of a serial number can be assigned.
Cannot figure out what I have done to screw this up!
Any ideas?
I think my problem is I need to Disable standard serial number generation (see attached snapshot of EPDM manual).
Where do I turn this off?
Or should I change something in my datacard?
I'm not clear as to what drives the serial number to increase in value.
Can anyone explain this?
Gary
Message was edited by: Gary
I figured it out!
I was linking a template box & a linked datacard box to the serial number so it was assigning the serial number twice.
I changed the "Default value" in the properties of the datacard box from "serial Number" to "Text Value" while leaving the same variable name.
Gary.
