I have an assembly with a global variable: A=1.
I want to drive parts in my assembly with this variable. ie. "D1@Sketch1@Part0.Part" = "D1@Length"-A (Where 'length' is a distance mate, that is a column in my design table). I have D1@Length, D1@Width, D1@Height as column headers in my design table.
I would also like to drive the value of A with the design table.
I created a column header in the design table called "$VALUE@A@equations".
When I exit the design table I get a warning in the upper right of my screen that states, "Column heading "$VALUE@A@equations" contains an invalid equation specifier.
Exiting table without completing model update."
I'm pretty green to using variables like this. I'm not sure if I have the syntax incorrect....or I'm just totally off base.
David,
Since you haven't gotten an answer here, you might try asking this in the Design Tables and Configurations forum (or Configurations and Design Tables forum, just coming back from vacation and I've forgotten everything I know about work).
Jerry S.
