Could someone help me?
I'm trying to import parts from mechanical desktop 2006, but, when I import it in SW it doesn't work, are just openning the sketches and not the parts or opens a solid without the resources, like in the models annex.
What should I do to have a file like the "C3.sldprt"?
Go annex:
"C.dwg (file in MDT6)"
"C1.sldprt (file with problem)"
"C2.sldprt (file with problem)"
"C3.sldprt (file that I want after import the MDT file)"
Thank you for you help...
Marcelo Cassol
FeatureWorks converted it without issue (file is attached). This is a simple part so I am assuming you have a more complex model that you need to convert?
