Re: how to check sheetmetal parts for a bend radius of 0
Keith Rice Nov 19, 2012 5:05 PM (in response to Nick Langer)Hi Nick,
If you uploaded parts containing these two exceptions then it would be easier for us to test code that might solve your problem.
Keith
Nick Langer Nov 19, 2012 5:25 PM (in response to Keith Rice)Hi Keith,
Here are the two conditions
-Nick
0BendTest9.SLDPRT.zip 49.7 KB
0BendTest8.SLDPRT.zip 34.5 KB
Nick Langer Nov 21, 2012 3:02 PM (in response to Nick Langer)Nvm, I figured out how to get the bend radius of the basebend. Turns out it is a subfeature of baseflange with type name of "SketchBend" and with this value I can catch both conditions. I still have one question, is there an easier way to find the type name of features than using a macro that gets the type name of a selected feature in an open part? Here is the heart of the feature data extraction, I left out the conditional parts that determine what has a zero bend radius since that was the easy part once I had all the feature data:
Dim swModelDoc As SldWorks.ModelDoc2
Dim swFeat As SldWorks.Feature
Dim swSubFeat As SldWorks.Feature
Set swFeat = swModelDoc.FirstFeature
Do While Not swFeat Is Nothing
Select Case swFeat.GetTypeName
Case "SMBaseFlange"
Dim swBaseFlange As SldWorks.BaseFlangeFeatureData
Set swBaseFlange = swFeat.GetDefinition
Application.Cells(xlCount, 9).Value = swBaseFlange.BendRadius
Set swSubFeat = swFeat.GetFirstSubFeature
Do While Not swSubFeat Is Nothing
Select Case swSubFeat.GetTypeName
Case "SketchBend"
Set swBaseBend = swSubFeat.GetDefinition
Application.Cells(xlCount, 15).Value = swBaseBend.BendRadius
Case Else
End Select
Set swSubFeat = swSubFeat.GetNextSubFeature()
Loop
Case "SheetMetal"
Dim swSheetMetal As SldWorks.SheetMetalFeatureData
Set swSheetMetal = swFeat.GetDefinition
Application.Cells(xlCount, 10).Value = swSheetMetal.BendRadius
Case "SM3dBend"
Dim swSketchBend As SldWorks.SketchedBendFeatureData
Set swSketchBend = swFeat.GetDefinition
Application.Cells(xlCount, 11).Value = swSketchBend.BendRadius
Case "ProcessBends"
Dim swBends As SldWorks.BendsFeatureData
Set swBends = swFeat.GetDefinition
Application.Cells(xlCount, 12).Value = swBends.BendRadius
Case "EdgeFlange"
Dim swEdgeFlange As SldWorks.EdgeFlangeFeatureData
Set swEdgeFlange = swFeat.GetDefinition
Application.Cells(xlCount, 13).Value = swEdgeFlange.BendRadius
Case "SMMiteredFlange"
Dim swMiterFlange As SldWorks.MiterFlangeFeatureData
Set swMiterFlange = swFeat.GetDefinition
Application.Cells(xlCount, 14).Value = swMiterFlange.BendRadius
Case Else
' Probably not a sheet metal feature
End Select
Set swFeat = swFeat.GetNextFeature
Loop
