2 Replies Latest reply on Nov 19, 2012 6:28 AM by Gordon Daugherty
    Sorting numbers
    Gordon Daugherty
      I wanted to sort my dimension to smallest number the largest number having a little trouble with doing the
      Ex. if the block is 5.000 x 2.000 x 1.500 I would like to 1.500 x 2.000 x 5.000 in custom properties
        • Re: Sorting numbers
          Artem Taturevych
          It's not completely clear what input do you have. I assume you have a string so you can use the following function:
              Debug.Print SortNumbers("5.000 x 2.000 x 1.500")
          Function SortNumbers(inputStr As String) As String
              Dim vNumbers As Variant
              vNumbers = Split(inputStr, "x")
              'bubble sort
              Dim i As Integer
              Dim j As Integer
              Dim temp As String
              For i = UBound(vNumbers) To 1 Step -1
                  For j = 0 To i - 1
                      If CDbl(vNumbers(j)) > CDbl(vNumbers(j + 1)) Then
                          temp = vNumbers(j)
                          vNumbers(j) = vNumbers(j + 1)
                          vNumbers(j + 1) = temp
                  Next
              Next
              For i = 0 To UBound(vNumbers)
                  SortNumbers = SortNumbers & Trim(vNumbers(i))
                  If i <> UBound(vNumbers) Then
                      SortNumbers = SortNumbers & " x "
              Next
          End Function
          ______________________
          Regards,
          Artem Taturevych
          Application Engineer at Intercad
          http://intercad.com.au/
          Tel: +61 2 9454 4444
