3 Replies Latest reply on Nov 19, 2012 2:55 AM by Artem Taturevych
    How to replace parts in drawing? Use API method.
    Yong Ning
      I hope use API method
      the a.sldprt replace b.sldprt in Drawing of a.slddrw
      In Drawing of a.slddrw, display b.sldprt.
      Record Macro,But don't repalce sldprt.
      ' C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\swx3712\Macro1.swb - macro recorded on 11/19/12 by Administrator
      Dim swApp As Object
      Dim Part As Object
      Dim SelMgr As Object
      Dim boolstatus As Boolean
      Dim Feature As Object
         Set Part = swApp.OpenDoc6("D:\Backup\我的文档\DrawingSld\a.SLDDRW", 3, 0, "", longstatus, longwarnings)
         Set Part = swApp.ActivateDoc2("a - 图纸1", False, longstatus)
        • Re: How to replace parts in drawing? Use API method.
          Artem Taturevych
          Use this method:
          http://help.solidworks.com/2012/English/api/sldworksapi/replace_referenced_document_example_vb.htm
          ______________________
          Regards,
          Artem Taturevych
          Application Engineer at Intercad
          http://intercad.com.au/
          Tel: +61 2 9454 4444
              Yong Ning
              Thank your like web.
              It's code
              Replace Referenced Document Example (VB)
              This example shows how to replace a referenced document with a different document
              ' Preconditions:
              '           (1) c:\samples\whistles.sldasm, whistle.sldprt, and whistleLonger.sldprt
              '               exist.
              '           (2) c:\samples\whistles.sldasm is not open.
              ' Postconditions: c:\samples\whistleLonger.sldprt replaced c:\samples\whistle.sldprt
              '               reference within c:\samples\whistles.sldasm.
              Option Explicit
              Const sReferencingDoc       As String = "c:\samples\whistles.sldasm"
              Const sOldDoc               As String = "c:\samples\whistle.sldprt"
              Const sNewDoc               As String = "c:\samples\whistleLonger.sldprt"
                  Dim swApp               As SldWorks.SldWorks
                  Dim bRet                As Boolean
                  bRet = swApp.ReplaceReferencedDocument(sReferencingDoc, sOldDoc, sNewDoc)
                  Debug.Assert bRet
              Dim sReferencingDoc, sOldDoc, sNewDoc
                  Dim bRet                As Boolean
                  Dim SwPart As SldWorks.ModelDoc2
                  Dim Str, Path
                  Set SwPart = swApp.ActiveDoc
                  Str = SwPart.GetPathName
                  Path = Left(Str, InStrRev(Str, "\"))
                  'Debug.Print Path
                  sReferencingDoc = Path & "a.slddrw"
                  sOldDoc = Path & "a.sldprt"
                  sNewDoc = Path & "b.sldprt"
                  'Debug.Assert bRet
