I have the opportunity to test a K5000 VGA with SolidWorks 2013.
I am using RealView and I have some questions and problems. I am testing this VGA on my old computer right now (first gen i7 @ 4Ghz), Windows 7 x64 and
1) While rotating the model with RealView I see what you can see in image 01. After I stop rotating it seems that some textures are applied to the model and I get the result that you can see in image 02. To generate image 02 I see that CPU is used. I was wondering if this behavior is normal and if it is possible to set SolidWorks so that the image 02 can be displayed also during rotation. Sometimes I get image quality 02 also during rotation, when using a 3D mouse, but I get 0.5fps or less. I never get image 02 while rotating with the mouse.
2) As you can see in image 03 the option “full scene anti-alias” is grayed out (Anti alias scenografia completa). I could force antialiasing in Nvidia drivers, but I would like to know if it is normal that I can’t select the full scene antialiasing directly in SolidWorks.
3) This is related to the previous two points: I have no antialiasing after I stop moving the model around. It seems that when I stop the movements the image is rendered with the textures without antialiasing.
Thanks!
