This makes day number two trying to solve this problem and still no answers. I'm running SolidWorks 2013 SP0 haven't had any issues with it until yesterday. When I attempt to open files from our server I get this error message.
If I click no nothing happens at all. If I click yes I then get a second error message.
I called tech support, but they deemed it a computer issue and not a SolidWorks issue. I don't really buy that. I can access everyother file type from that same location with no issues. Solidworks is the only software that has an issue reading or writing to the server. Any and all suggestions on this problem would be much appreciated.
Nick
I have had this happen to me in the past. If your files are out on a server they may be locked because your work station went down when you had those files open. If that is the case you have to have admin login rights. If you do not have your IS department go and unlock the files. After that they should open like normal.
