Is there an add-in or third-party program that can take a text file containing a list of drawing file paths and batch plot them? The programs that I've found produce a blank printout when referencing a drawing that is within the Workgroup PDM Vault. I understand that making use of files inside the vault without going through Workgroup PDM is not possible, but there must be some way to batch plot within the vault. I really can't use task scheduler, because I need to import the drawing list from a text file rather than manually browse and select drawings.
I have to imagine that most manufacturing companies out there have this same need. The ERP system outputs a list of drawings needed for manufacturing orders to a text file, and this file is processed through batch plotting software to produce prints for shop packets. Is there a way to do this for files that are in Workgroup PDM's vault?
Dan, you can use the Task Scheduler to do some of what you are trying to do. Maybe you could over print in groups, then do a compare afterwards but I don't think there is a direct method you are referring to. Sorry.
