I am trying to make this spring flexible, so that the spring does not go through the other parts. It will not allow me to make the spring flexible. Any Ideas?
Tony,
I think your spring is cleaner than the one in the video I linked to, since it eliminates creating a new plane, but I have a question. You said to mate the endpoints in the assembly, but I couldn't get that to work. Am I missing something?
I mated one end of the spring (the end at the top plane), then edited sketch1 in the assembly and make the un-defined endpoint coincident with the surface of the component of my assembly. That worked well.
Check out this video. I've used this method a time or two, although you may need to Ctrl+Q your assembly occasionally to update it.
