Hello folks,
I have a half inch threadolet that is used on everything and I am trying to set it up to drag and drop onto any pipe and have it penetrate the pipe at a specified size (if I change the threadolet configuration it should change the hole size in the pipe aswell)
I understand that you cannot use a MateReference to drop the threadolet onto the pipe but will need a dimension there. Unless you can and I am unaware of this (please educate me - also if you can make a drag drop item detect the pipe size it is being dropped onto, i would also like to know more about this)
So at the moment, I have a simple part with a Cpoint and Rpoint that i drop onto a line that penetrates from the main pipe line (perpendicular lines) So I then penetrate that line into the main pipe line, I then dimension the threadolet so it looks like it is sitting on the pipe surface then change the penetrating line to a construction line. It kind of works ok.
It is a bit fiddly and wondering if there is an easier solution.
Hello Ben,
When I made my olets for piping I create a circle to represents my header pipe & then I create revolved feature of the olet profile. I follow by a cut feature to create the seat for the olet to sit on the header pipe. This allows the olet to always be located based on your header pipe OD which is how the literature on olet installation is supplied.
Making a hole in a routed pipe is where you are going to be upset about your olet. It's sort of a out of sight out of mind principal. The way it has been explained to me about how olets are installed in piping is that they are welded to the header pipe & then the hole is drilled into the header pipe to suite the olet branch size & location. Then you continue with piping from the olet. So as a result it is a post process that shouldn't need any detailing.
Other then the hole feature in the pipe you can set up your route 'C points' based on your header & your olet branch size. As a result all you need to do is drop the olet into my assembly & select the branch size as if I was dealing with a reducing tee. The down side is that you need to create a split point on the header pipe when dropping it on the header. I end up deleting the split point & mate it to the sketch line.
I hope this was helpful.
Cheers
