Title pretty much sums it up. I have a master model with several bodies saved out to other parts. Can't figre out how to fix broken references.
Tim
Tim
I can't figure out what you mean by
"in the derive part/s to reassign the master part file and/or the solidbodies that were assigned in the save bodies or split part feature."??
In SW2012 or 2013 Go to Tools>Options>System Settings>Messages/Errors/Warnings and find the dismissed message that matches my screenshot above. Click the box next to that line, and then click "OK" out of the System Options dialog box.
In SW2011 or earlier, go to Tools>Options>System Settings>Advanced and click on the dismissed message.
Then try again.
Hi Tim,
What version of SW are you using? If you are on SW2011 > then you can edit the stock feature (in the FeatureManager) in the derive part/s to reassign the master part file and/or the solidbodies that were assigned in the save bodies or split part feature.
Regards
Mark
