18 Replies Latest reply on Nov 15, 2012 8:36 AM by David Brissenden
    Printing Issue
    David Brissenden
      I'm trying to print a document out to a specific printer and SW 2006 is having none of it.
      I've followed the example here: http://help.solidworks.com/2011/English/api/sldworksapi/Print_Drawing_as_High_Quality_Example_VB.htm with my own printer but it is adamant it wants to always print to one specific printer and not the one I choose.
      The code I have is:
      Private Sub cmdPrintDrawings_Click()
          Dim swModelExt As SldWorks.ModelDocExtension
          Dim swPageSetup As SldWorks.PageSetup
          Dim lSheets(0) As Long
          Set swModel = swApp.ActiveDoc
          Set swPageSetup = swModel.PageSetup
          swPageSetup.Orientation = 2
          lSheets(0) = 0
          Set swModelExt = swModel.Extension
          swModelExt.PrintOut2 lSheets, 1, False, "\\Test\Test Plotter", ""
      What am I doing wrong?
        • Re: Printing Issue
          Artem Taturevych
          Try to set the printer via ModelDoc2::Printer  and use ModelDoc2::PrintDirect  for printing.
          ______________________
          Regards,
          Artem Taturevych
          Application Engineer at Intercad
          http://intercad.com.au/
          Tel: +61 2 9454 4444
            David Brissenden
            Ok , all seems solved after a reboot.....something somewhere seems to have got confused (more than me!!)
            The next question is how do you set the papersize?  There is a PrinterPaperSize property under the PageSetup but I am finding conflicting info regarding setting the papersize.  Some information is saying A3=8 A4=9 whilst others are saying different A2=8 A1=9.
            Obviously different printers have different paper sizes available to print on, but how do you find our the correct constant?
            Thanks for your help guys.
                Deepak Gupta
                You may define the paper size using PrinterPaperWidth and PrinterPaperLength
                    David Brissenden
                    I thought this was possible however
                        swPageSetup.ScaleToFit = True
                        swPageSetup.PrinterPaperLength = 2970
                        swPageSetup.PrinterPaperWidth = 4200
                    this is what I set and it doesn't print A3 as it is supposed to.  I've tried swapping the length and width around but there is no difference.  The printer supports A3.....so I can't see why this doesn't work
                      David Brissenden
                      If I set:
                      The printer seems to think it is JISB4 size.
                      I'm guessing this is an issue with scaling but still doesn't alter the fact that it doesn't print A3 / A4 as it should.
                      Cannot believe there are so many issues with this software....
                          Michael Jeffries
                          I don't believe it's so much solidworks as it's fairly unfriendly to access printer specs (for the selected printer) in VBA.  I can easily tell you what paper sizes are available to print on using VB.NET, but when it comes to VBA I am at a loss..  I have two different network printers that (as you pointed out) have different paper sizes listed (from excel or any other application print dialog):
                          RicohCOL
                          PaperSize / PaperName
                          0       12" x 18"
                          17       11" x 17"
                          5       Legal (8.5" x 14")
                          1       Letter (8.5" x 11")
                          7       Executive (7.25" x 10.5")
                          6       5.5" x 8.5"
                          8       A3 (297 x 420 mm)
                          9       A4 (210 x 297 mm)
                          11       A5 (148 x 210 mm)
                          70       A6 (105 x 148 mm)
                          12       B4 JIS (257 x 364 mm)
                          13       B5 JIS (182 x 257 mm)
                          88       B6 JIS (128 x 182 mm)
                          0       8" x 13"
                          0       8.25" x 13"
                          14       8.5" x 13"
                          20       Com10 Env. (4.125" x 9.5")
                          37       Monarch Env. (3.875" x 7.5")
                          27       DL Env. (110 x 220 mm)
                          31       C6 Env. (114 x 162 mm)
                          28       C5 Env. (162 x 229 mm)
                          0       Custom Paper Size
                          RicohENG
                          0       12" x 18"
                          17       11" x 17"
                          6       5.5" x 8.5"
                          8       A3 (297 x 420 mm)
                          9       A4 (210 x 297 mm)
                          0       8" x 13"
                          0       8.25" x 13"
                          14       8.5" x 13"
                          0       Custom Paper Size
                          Where Modeldoc2.pagesetup.printerpapersize = PaperSize (from above tables)
                          These are not in any relation to swDwgPaperSizes_e (enumeration).
                          You can use the following to print, but I was unable to 1) check selected printer paper sizes and 2) find the callout for A0, A1, A2, etc...
                              Dim swModel As ModelDoc2
                              Dim swDraw As DrawingDoc
                              Dim swPart As PartDoc
                              Dim swAsm As AssemblyDoc
                              Dim swSheet As Sheet
                              Dim sheetsize As String     'Sheet Size Variable (retreived from SW)
                              Dim paperSize As swDwgPaperSizes_e
                              Dim width As Double
                              Dim height As Double
                              Sub swPrint()
                                  Select Case swApp Is Nothing
                                      Case True
                                          Set swApp = New SldWorks.SldWorks
                                  End Select
                                  Select Case swModel.GetType
                                      Case swDocumentTypes_e.swDocDRAWING
                                          Set swDraw = swModel
                                      Case Else
                                          swApp.SendMsgToUser ("Please open a drawing document and try again!")
                                          Exit Sub
                                          'Nothing
                                  End Select
                                  swPrintSettings("RicohCOL")     'Prints to the Specified Printer Name, you can get your printer names by going to Windows Button >>> Devices and printers
                              Sub swPrintSettings(ByVal PrinterName As String)
                                  Dim swPageSetup As PageSetup
                                  swModel.Printer = PrinterName
                                  Select Case Get_SheetSize()
                                      Case "A"
                                          swModel.PageSetup.PrinterPaperSize = 1
                                      Case "AV"
                                      Case "B"
                                          swModel.PageSetup.PrinterPaperSize = 17
                                      Case "C"
                                      Case "D"
                                      Case "E"
                                      Case "A0"
                                      Case "A1"
                                      Case "A2"
                                      Case "A3"
                                          swModel.PageSetup.PrinterPaperSize = 8
                                      Case "A4"
                                          swModel.PageSetup.PrinterPaperSize = 9
                                      Case "A4v"
                                      Case "UserDefined"
                                  End Select
                                         swModel.PrintOut 1, swDraw.GetSheetCount, 1, False, swModel.Printer, swPageSetup.ScaleToFit, False
                                      Case Else
                                          MsgBox ("Open a drawing and try again")
                                          Exit Sub
                                  End Select
                              Function Get_SheetSize() As String
                                  Set swSheet = swDraw.GetCurrentSheet
                                  If Not swSheet Is Nothing Then
                                      paperSize = swSheet.GetSize(width, height)
                                      Debug.Print ("swDwgPaperSize = " & paperSize)
                                      Select Case paperSize
                                          Case swDwgPaperSizes_e.swDwgPaperAsize
                                              sheetsize = "A"
                                          Case swDwgPaperSizes_e.swDwgPaperAsizeVertical
                                              sheetsize = "AV"
                                          Case swDwgPaperSizes_e.swDwgPaperBsize
                                              sheetsize = "B"
                                          Case swDwgPaperSizes_e.swDwgPaperCsize
                                              sheetsize = "C"
                                          Case swDwgPaperSizes_e.swDwgPaperDsize
                                              sheetsize = "D"
                                          Case swDwgPaperSizes_e.swDwgPaperEsize
                                              sheetsize = "E"
                                          Case swDwgPaperSizes_e.swDwgPaperA0size
                                              sheetsize = "A0"
                                          Case swDwgPaperSizes_e.swDwgPaperA1size
                                              sheetsize = "A1"
                                          Case swDwgPaperSizes_e.swDwgPaperA2size
                                              sheetsize = "A2"
                                          Case swDwgPaperSizes_e.swDwgPaperA3size
                                              sheetsize = "A3"
                                          Case swDwgPaperSizes_e.swDwgPaperA4size
                                              sheetsize = "A4"
                                          Case swDwgPaperSizes_e.swDwgPaperA4sizeVertical
                                              sheetsize = "A4V"
                                          Case swDwgPaperSizes_e.swDwgPapersUserDefined
                                              sheetsize = "UserDefined"
                                      End Select
                                      Debug.Print ("Sheet Size: " & sheetsize)
                                  Get_SheetSize = sheetsize
                              End Function
