Hi guys, I'm using flow simulation on a rear wing I designed for my school's Formula SAE car. I have two elements and two early iteration endplates. For whatever reason, when I go to start flow-sim for the assembly, solidworks decides to crash out. We're using the 2011-2012 student version of solidworks. The flow simulatino seem to work fine when it's used for a single part. The rear wing I'm doing the simulation is fully defined as well. Any help is much appreciated!
-Alex
At what point does it crash out? Does it crash when you add Flow in or does it crash once you start to run the simulation?
I have found that assemblies can become corrupt over time and in some instances have been forced to go back to an older version of the assembly I had archived.
If that is not the problem and it is crashing during adding Flow in, I would check for interferences and invalid contacts. Those can cause crashing.
