incompatible meshes and multi-point restraints
Question asked by Mark Mariak on Nov 12, 2012
Latest reply on Nov 13, 2012 by Anthony Botting
I understand that "multi-point restraints" are used internally when the mesh is incompatible (see excerpt below from SW help- "Guidelines on Studies with Contact Conditions"). Can someone explain in some detail what is being done since I'm running a study on an assembly which results in incompatible meshes and would like to understand what errors could be introduce by incorporating this type of restraint.
"Bonding is achieved by merging nodes when the mesh is compatible or by using multi-point restraints internally when the mesh is not compatible. Bonding incompatible meshes can generate local stress concentrations in the bonded areas."
