I have a very easy questions...I guess...even though I could not find the solution through the help of the software.
I have an assembly made of different parts.
I would like to combine three bodies of three different parts with the body of another part. The combine allows only to merge parts, whereas I wanna merge bodies.
Is there an easy way for doing it, or the easiest way would be to combine the parts in a new part and then slowly cut all the bodies which are not needed?
Thanks a a lot
Antonio
I use Solidwors 2010 SP5.0
Antonio,
You will need to combine the parts into a single part in order to combine the bodies.
As far as cutting away unwanted bodies, you might be able to use the Indent or Combine features.
