I have an extremly annoying problem which is getting on my nerves right now. The problem is that (sometimes, but more often than not) parts and sub-assemblies graphically disappear in an assembly, or filckers as I zoom in and out and if i continue to work after a while the graphics don´t even display the coordinate system correctly which means that I visually select a point thats actually x points away. I´ve contacted my csvr but the only help I got was the advice to change card driver which hasn´t helped even a tiny little bit.
At first I thought it was a hardware related problem but it seams to be something that sticks to the actual file because if I open the file on a diffrent machine the problem persists.
So now I´m stuck using Software openGL...
I´ve tried to reset the option in Solid and the settings of the graphic card but it doesnt seem to help.
If anyone´s got any suggestions or ideas of what I could do to relieve or fix the problem It´ll be appreciated.
Which version & SP of SW?
Did you perform a clean install of SW?
Do you have multiple versions of SW installed?
What are your computer specs?
Have you tried running a repair or resetting the registry?
