Hello. So I have designed a coil over shock with 2 springs on it. The springs should compress at different rates in a real life senario. As I manual compress and the assembly only the bottom spring compresses. How can I add spring rates between the components so that when I put this coilover into a suspension system and cycle the suspension; the springs will compress at the proper rates?
Ive attached the Folder. The complete assembly is "Coilover 14 Inch"
Thanks for any help.
Is this even in the right place. Currently I am not to the point of worrying about actual simulation or animation. I just want the parts to react properly when cycling components in the asssembly.
