When I am using Hole Wizard and I come to the section end condition, I have a blind condition and I type in a value such as .15625 as my depth, Hole wizard will then round this value to two decimal places and will give me a depth of .16. I've looked through my Options > Document Properties > Dimensions and set my precision to a .XXXX but this doesn't seem to fix the problem.
What is really troublesome about this is that when using Hole Callout in a drawing that value will remain .16 even when the precision is raised there, showing .16000.
Dacia,
I did a little playing around and got the same results that you did. Then I went to the Document Properties for my PART and changed Units to Decimal, showing 4 decimal places. Then the dimension showed correctly in the drawing when it was also set for 4 decimal places. I don't have a clue why but it worked.
