Folks,
Lets say our toolbox is on the C drive. Customer sends over an assembly using pack n go. Customers toolbox resided on the D drive.
Any easy workaround other than re-pointing each toolbox part???
Tim
Folks,
Tim
First of all. the toolbox components should be in the same folder as your CAd, as it were pack&go'd -
If you then are thinking off moving these new toolbox items to your on toolbox folder and then repoint, I believe you would only have to point to the first toolbox item, and it should then find the rest automatically.
and should you find yourself in getting a Pack&Go with the toolbox items included, the toolbox will just autogenerate the items in your standard folder with your own settings.
If the customer sent you the Pack and Go files, then toolbox files from the customer should have been in the same zip file or folder. To open simply uncheck the option "Make this folder the default search location for Toolbox components" under Tools > Options > Hole Wizard/Toolbox.
