I am looking to clean up our current PDM Workgroup Vault directory. If I run a batch file with the following command, will that only delete folders named "obsolete". I have noticed that in our vault there are some folders named "XXXX obsolete" and I only want to delete the one's labeled obsolete. I'd also like to put this into a script and/or VB.NET program so that I can script it to run after shutting down the vault.
rm-recurse D:\SW_Vault obsolete
Thanks.
You might want to look at this: Delete Obsolete Folders
I would suggest you to take a back of the vault and try the script on few folder (create some new folders with a string which you can use in the script to delete those folders only)
