Is it possible to fill up file properties data from a BOM table to custom properties tab?
At the moment the go in the custome specific properties.
Pengue Giovanni wrote:
Thank,
Is there a way to fill up inside custom properties and not in custom specific properties?
Do you mean configuration specific properties?
I couldn't find a direct way to get the properties in custom from BOM
You can run a macro to move the configuration specific properties generated by BOM to custom properties, if you want.
Yes,
Whenever you fill the column in the BOM, it goes to configuration specfic properties of the part
If you break the link between BOM and part, then no
