18 Replies Latest reply on Jun 6, 2013 6:54 PM by Josh Brady
    Macro doesn't open in 2013sp0
    Nico Van Gils
      Having a problem opening macro's in SW2013 sp0:
      - Downloaded a 3D file (.swb) of a bearing from the SKF website (file in attach)
      - Tried to run it in SW2013 sp0. (this is the first macro I ran)
      - Nothing happens. SW doesn't even hang.
      - When editing the macro and debugging it gives a few errors. But my knowledge of VB isn't that great to solve it.
      Already tried what's in the tread concerning SW2013 beta 1
      https://forum.solidworks.com/message/301044#301044
      Anyone having the same problem?
      Nico
        • Re: Macro doesn't open in 2013sp0
          Hello all,
          Further to Artem's suggestions, please find below the changes that need to be made in order to use the Win32 Folder Browser API functions used in the macro::
            Change #1
            Public Type BROWSEINFO
            #If VBA7 Then
                hWndOwner       As LongPtr
                PIDLRoot        As LongPtr
                pszDisplayName  As String
                lpszTitle       As String
                ulFlags         As Long
                lpfnCallback    As LongPtr
                lParam          As LongPtr
                iImage          As Long
            #Else
                hWndOwner       As Long
                PIDLRoot        As Long
                lpszTitle       As String
                ulFlags         As Long
                lParam          As Long
                iImage          As Long
            #End If
            End Type
            Change #2
            #If VBA7 Then
              Public Declare PtrSafe Function SHBrowseForFolder Lib "Shell32" (lpbi As BROWSEINFO) As Long
              Public Declare PtrSafe Function SHGetPathFromIDList Lib "Shell32" (ByVal pidList As LongPtr, ByVal lpBuffer As String) As Long
              Private Declare PtrSafe Sub CoTaskMemFree Lib "ole32" (ByVal hMem As LongPtr)
            #Else
              Public Declare Function SHBrowseForFolder Lib "Shell32" (lpbi As BROWSEINFO) As Long
              Public Declare Function SHGetPathFromIDList Lib "Shell32" (ByVal pidList As Long, ByVal lpBuffer As String) As Long
              Private Declare Sub CoTaskMemFree Lib "ole32" (ByVal hMem As Long)
            #End If
            Change #3
            Public Function BrowseForFolder() As String
              Dim tBI         As BROWSEINFO
            #If VBA7 Then
              Dim lngPIDL     As LongPtr
            #Else
              Dim lngPIDL     As Long
            #End If
          With these changes the code can be used in SW2012 and earlier and also in SW2013 and later.
          There is another entry on the SolidWorks Forum on the Win32 APIs used in this macro:
                          How to use Win32 APIs from a SolidWorks VBA macro which must support SW2012 & SW2013.
                          https://forum.solidworks.com/docs/DOC-2241
          More general information can be found at:
                          SolidWorks 2013 API changes
                          https://forum.solidworks.com/docs/DOC-2141
          And now is the time to think about visiting SolidWorks World 2013:
          Title:Visual Basic® for Applications 7: Getting SolidWorks Macros Ready for 64-Bit
          Presentation Category:Design Automation
          Sub-Category:API
          Session Type:Breakout Session
          Presentation Level:Intermediate (1-3 years' experience)
          Abstract:Hear an introduction to the language changes of Visual Basic for Applications 7 in SolidWorks 2013, supporting 64-bit. This presentation will outline scenarios to adapt existing macros using external Windows® and ActiveX® controls dlls for use with SolidWorks 2013, while keeping them backward-compatible.
          Attendee Benefits:Attendees will learn to take advantage of the new VBA 7 features and what needs to be done to protect investments in existing VBA macros.
          Speaker:
          Frank Lindeman
          SolidWorks Partner Technical Manager (API)
          Dassault Systèmes SolidWorks
          Frank Lindeman has been a technical manager with the SolidWorks API group since 2004, working with customers, solution partners, and OEM partners to build powerful SolidWorks-based applications.
          Date:January 22, 2013
          Day and Time:Tuesday, 10:30 AM - 12:00 PM
          Regards,
            Frank
          SolidWorks API, Partner Technical Manager
          Cambridge, UK
              FYI: I have reached out to the SolidWorks partner involved in the generation of the SWB macros for SKF product models, in the hope this problem can be resolved at source.
              Regards,
                Frank
              Cambridge, UK
                  Nico Van Gils
                  Frank,
                  Thank you for contacting the guys from SKF. That would resolve a lot of problems.
                  Also thank you for the code to be changed in the macro's. But with the low amount of knowledge concerning macro's and programming them this isn't easy to do.
                  It is a bit like driving a car. You can perform excellent on the road but know absolutely nothing about how the engine works.
                  nico
                      Hello Nico,
                      To be clear, I only contacted the partner who did the work for SKF, to make them aware of the issue.
                      Although I had attached a fixed macro to my original reply, I realized later I made the changes in the Visual Basic editor, leaving some editor specific lines in the saved out code.
                      I now made the changes in a pure text editor, so the fixed macro is as close as possible to the one you downloaded.
                      See attached.
                      OK, car's fixed now. Happy driving.
                      Regards,
                        Frank
                      Cambridge, UK
                  JJ Meijer
                  I created a swb loader that will replace the browse for folder function and use the FolderBrowserDialog from .net framework.
                  Use open with... or drop (mutliple) .swb files on top of the .exe, batch load is possible this way. Now you can load vba6 .swb files "directly" in sw2013.
                  framework 4.0 required
                  Here is the code:
                  using System;
                  using SolidWorks.Interop.sldworks;
                  using System.IO;
                  using System.Text;
                  using System.Windows.Forms;
                  namespace SwbLoader
                      class Program
                          [STAThreadAttribute]
                          static void Main(string[] args)
                              //Programm used correctly?
                              if (args.Length == 0)
                                  Console.WriteLine("No file selected!");
                                  Console.ReadKey();
                                  return;
                              //configure dialog
                              var dial = new System.Windows.Forms.FolderBrowserDialog();
                              dial.ShowNewFolderButton = true;
                              dial.SelectedPath = "";
                              //exit on cancel
                              if (dial.ShowDialog() != System.Windows.Forms.DialogResult.OK)
                                  return;
                              //configure file paths
                              string temppath = Path.GetTempPath();
                              string targetpath = dial.SelectedPath;
                              //loop through files
                              foreach (string str in args)
                                  Console.WriteLine("Processing: " + str);
                                  string filecontent;
                                  using (var tr = File.OpenText(str))
                                      filecontent = tr.ReadToEnd();
                                  try
                                      if (filecontent.Contains("Private Type BROWSEINFO"))
                                          int brwsinfoStart = filecontent.IndexOf("Private Type BROWSEINFO");
                                          int brwslength = filecontent.IndexOf("Private Declare", brwsinfoStart) - brwsinfoStart;
                                          filecontent = filecontent.Remove(brwsinfoStart, brwslength);
                                      else
                                          throw new Exception("\"Private Type BROWSEINFO\" not found!");
                                      if (filecontent.Contains("Public Function BrowseForFolder()"))
                                          int brwsfuncStart = filecontent.IndexOf("Public Function BrowseForFolder() As String");
                                          int brwsfuncLength = filecontent.IndexOf("Sub CreatePart0", brwsfuncStart) - brwsfuncStart;
                                          filecontent = filecontent.Remove(brwsfuncStart, brwsfuncLength);
                                      else
                                          throw new Exception("\"Public Function BrowseForFolder()\" not found!");
                                      if (filecontent.Contains("Private Declare Function SHBrowseForFolder"))
                                          int DecStart = filecontent.IndexOf("Private Declare Function SHBrowseForFolder");
                                          int Declen = filecontent.IndexOf("Private Const", DecStart) - DecStart;
                                          filecontent = filecontent.Remove(DecStart, Declen);
                                      else
                                          throw new Exception("\"Private Declare Function SHBrowseForFolder\" not found!");
                                      if (filecontent.Contains("storePath=BrowseForFolder"))
                                          filecontent = filecontent.Replace("storePath=BrowseForFolder", "storePath=\"" + targetpath + "\"");
                                      else
                                          throw new Exception("\"storePath=BrowseForFolder\" not found!");
                                  catch(Exception ex)
                                      Console.WriteLine(ex.Message);
                                      Console.WriteLine();
                                      Console.WriteLine("Could not detect standard text structure!");
                                      Console.ReadKey();
                                  using (var tw = new StreamWriter(Path.Combine(temppath, "temp.swb")))
                                      tw.Write(filecontent);
                                  RunMacro(Path.Combine(temppath, "temp.swb"));
                          static void RunMacro(string path)
                              var swapp = new SldWorks();
                              swapp.Visible = true;
                              swapp.RunMacro(path, "", "main");
                    Problem and solution are now documented in Knowledge Base Solution S-061791.
                    The SolidWorks partner involved in the generation of the SWB macros has rectified the problem.
                    Regards,
                      Frank
                    Cambridge, UK
